Sponsored by: Auxito
IFS Gears
Old Nov 28, 2005 | 06:04 PM
todder53's Avatar
todder53
IFS Gears
Where can i find deeper gears for my 2003 F150 FX4 ifs? Also what is the stock gear ratio?
Old Nov 28, 2005 | 07:00 PM
todder53's Avatar
todder53
I found the gear ratio using a vin decoder it was 3.55 with limited slip. Now is the front a 8.8?? Whats the rear 8.8 or 9.75??
Old Nov 28, 2005 | 07:15 PM
ford390gashog's Avatar
ford390gashog
todd,
first off what engine? the front is a open 3.55 the rear is a l/s 3.55 the front diff is a 8.8 the rear could be either 9.75 or 8.8.
Old Nov 28, 2005 | 07:20 PM
kspilkinton's Avatar
kspilkinton
The front is a reverse cut 8.8... the aftermarket gear catalogues shows these are available in 3.73s, 4.10s, and 4.56s. The rear can be either an 8.8 or 9.75, and it doesn't matter which engine you have, contrary to popular opinion.
Not quite sure on the positive identifier (bolt #s and shape of cover), but the truck comes from the factory with the tag hanging off one of the bolts. It has the ring gear size incorporate into the code on the second line.
Should show some thing like this:
XXXXXXXXXXXX - 1 st line - Date and build code
3L55 8 8 XXXX - second line for an 8.8 with 3.55 Limited Slip
3L55 9 75 XXXX - second line for 9.75 with 3.55 Limited Slip
I show 3.73's only offered in the 8.8" rear. The 4.10s and 4.56s are in both sizes.
Hope that helps.
-Kerry
Old Nov 28, 2005 | 07:31 PM
todder53's Avatar
todder53
Thanks for the info i looked and my truck has a 8.8 in the rear.
