arbitration needed, about 4x4
Old Nov 28, 2005 | 01:36 PM
ytc's Avatar
ytc
There is this guy, we got into a long arguement.
He insisted that with a part-time 4x4 system, you can't engage it all the time when driving on snow. Instead, he thinks you should use it only when you start from steady, and disengage it after you got the speed.
I had a clear thought in mind. But this guy just don't belive it. So, you guys here are the pros. Could you tell us, if you keep your part-time 4H engaged almost all the time when driving ON SNOW? I believe all the f-150s, super duties with 4x4 have only the part-time one.
Appreciate it.
Old Nov 28, 2005 | 02:21 PM
ytc's Avatar
ytc
just one quick poll is perfect for me.
Do you drive with the part-time 4H engaged when cruising, with snow on road? Y/N?
Old Nov 28, 2005 | 02:31 PM
fordmantpw's Avatar
fordmantpw
Depends on the conditions. If the road is covered, I leave it in 4x4 Hi. If it is partly covered, I just switch in and out when I need it. You are right, he is wrong!
Old Nov 28, 2005 | 07:30 PM
osbornk's Avatar
osbornk
Totally Agree!
Old Nov 29, 2005 | 08:43 PM
1workhorse's Avatar
1workhorse
As long as the road is covered I use 4hi.
Old Nov 29, 2005 | 09:03 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Just ask yourself - is the surface slippery? If the answer is yes - leave it in 4X. Applies to mud, snow, grass, sand, anything. You need the 4X for traction, but there must be enough slippage between axles to avoid "windup" of the gear train.
Old Dec 15, 2005 | 01:43 PM
top2002's Avatar
top2002
I drive in snow all the time and if the road is slippery I leave it in 4H. I dont know if its good but on the roads I drive I usually drive at about 80 ( If no amatures are driving around me) So far three 150's and never an issue.
