Strange Problem
Old Nov 28, 2005 | 08:02 AM
Jay Bundick's Avatar
Jay Bundick
Strange Problem
2002 Excursion with 5.4 engine. When heater is turned on, high beam headlights come on automaticlly. Can remove the fuse to the headlights and the high beams still come on. Anyone ever had this problem?
Old Nov 28, 2005 | 11:14 AM
rlh68050's Avatar
rlh68050
WTF??? This is a new one. Do you have the automatic climate control??
Old Nov 28, 2005 | 11:49 AM
Jay Bundick
Do not have automatic climate control. This happens whenever any controls for A/c, heater or even if the blower switch is activated. If none of the heating/cooling controls are activated, lights work correctly. Only the hi beams come on, not the low beams or fog lights. ?????
Old Nov 28, 2005 | 03:18 PM
cficare's Avatar
cficare
Defective GEM.
Old Nov 29, 2005 | 07:36 AM
rlh68050's Avatar
rlh68050
Originally Posted by cficare
Defective GEM.
That would be my first thought. You need to get to someone who has access to a Ford NGS or WDS. These scantools can access the GEM module and run self tests/code checks. Should be some error codes set if the GEM is faulty. If I get a chance, I will hook my NGS up to my '01 and play around a bit to see what tests are available.
