Offroad & 4x4
Clevis or D-ring
Old Nov 27, 2005 | 10:22 PM
Kansas-Mike's Avatar
Kansas-Mike
Clevis or D-ring
I'am trying to find D-rings for the front of my F250,the kind that bolt up to the front shackles.
Thanks for the help.
Old Nov 28, 2005 | 09:04 AM
fishmanndotcom's Avatar
fishmanndotcom
i dont follow exactly what you are wanting here
D-rings are basically rings in the shape of a D that are attached to a trailer or truck by a bracket that looks like a piece of tube cut in half and fit over the flat part of the D-ring. it is then welded (some are bolt on but they are not rated for heavy loads)
http://www.all-trailer-equipment.com...ing1inDia.html
clevis/shackles are attched to trailer/truck by a piece of solid steel plate with a hole in the middle and welded in the desired position. the shackle/clevis is then bolted on using the provided
http://cache1.pirate4x4.com/tech/bil...y/Shackels.jpg
hope that helps
-cutts-
Old Nov 28, 2005 | 09:14 AM
chrono4's Avatar
chrono4
d rings for the shackles? im not to sure on that, i would go with a good frame mounted d ring, or at least a good hook.
