gears
Old Feb 10, 2002 | 08:57 PM
79_ford_400_guy's Avatar
79_ford_400_guy
gears
would you recomend 4.10 gears or 3.73 gears if im gonna be mud raceing my 79 ford f-150 with a 400 attached to a c-6 tranny? will there be much diff. as far as it kicking down adn get going......if you can tell me when each top out it would be appreciated thanks kevin
Old Feb 10, 2002 | 11:17 PM
zs_tx's Avatar
zs_tx
gears
i have 3.73s in a 3/4 ton with a Granny 4 and i top out around 5000 rpm at 90 mph, or better if i mess with the fuel and carb, but it isn't very cheap gas wise if you are gonna drive the truck very far because the milage will eat your wallet like fresh acid with any thing over 3.** ... just thought i would add my two cents.
1973 F-250
390 2V stock
4 on the floor <lookin for a 5th>
3.73 rear end
one crappie radio, but awsome pipes...
Old Feb 11, 2002 | 08:52 AM
Ford79's Avatar
Ford79
gears
What size tires are you using? Tire size has a lot to do with gear selection.
Old Feb 11, 2002 | 08:44 PM
79_ford_400_guy
gears
i am using 33's does anyone know where 4.10's top out???????
Old Feb 11, 2002 | 09:12 PM
jowilker's Avatar
jowilker
gears
