weird stuff please help!
Old Nov 27, 2005 | 07:47 PM
83stepside32784's Avatar
83stepside32784
Question weird stuff please help!
hi all i have an 81 F-150 302 4spd 4x4 the problem im having is at night when im driving i turn a corner and the dash lights flicker and both turn signals blink when it straitins out its fine till i turn again. im puzzled pls help its my every day driver and i love this truck, but my wife doesnt ,thanks
Old Nov 27, 2005 | 09:22 PM
fordborn's Avatar
fordborn
sounds like you have rubbed a spot in the wiring harness that goes down the column. When you turn it probably rubs it and grounds out. I would check the wiring there first.
Old Dec 4, 2005 | 02:40 PM
83stepside32784
thanx for the help il check that
Old Dec 5, 2005 | 01:40 AM
Lee Lichterman's Avatar
Lee Lichterman
It could also be the body leaning and straining the ground to battery connection. Make sure you have some slack in your battery cables. I have seen some that are so tight there is no tolerance for body lean and bumpy roads.
Good Luck,
Lee
