87 efi 302
Old Nov 27, 2005 | 02:07 PM
wagiles's Avatar
wagiles
87 efi 302
had problems with truck running... replaced fuel filter, o-ring in priming bowl for inline fuel pump, new connectors coming out of coil truck stop running after a little while. could it be the module or something else
Old Nov 27, 2005 | 02:20 PM
phoneman91's Avatar
phoneman91
What exactly are the problems?? Is the engine quiting when the engine is already warm or when it is warming up?? Or is the engine quiting when accelerating?? What are the circumstances when the engine quits??
Old Dec 3, 2005 | 10:01 PM
wagiles's Avatar
wagiles
yes after truck is warm it will get to a low idle and quit running. i took off the control module found it to be loose in the first place. put new contactor compound on back plate tightened the one screw it has left in it as much as poss. truck ran excellent for about a total of a couple of hours and quit again. is module weak enought to not hold the truck but good enough to test good? or do i need to look else where on the truck. oh yeah i replaced the fuel filter, inlinefuel pump, and the fuel pump in the tank.
