low idle
Old Nov 27, 2005 | 08:11 AM
time537's Avatar
time537
low idle
my 99 4.0 auto ranger idles fine somedays but on other days it wont idle enough to keep the truck running any suggestions
Old Nov 27, 2005 | 11:03 AM
RangerPilot's Avatar
RangerPilot
Check and clean the Idle Air Control valve (IAC). It's usually the source of these problems and an easy fix.
Old Nov 27, 2005 | 04:09 PM
probedude's Avatar
probedude
Do what RangerPilot mentioned but also clean the throttle body plate. If you're due for a tuneup, also perform that. (if you do get spark plugs, don't go for the fancy ones - you're likely to create more problems)
