boring out a 400
Old Feb 12, 2002 | 09:25 PM
79_ford_400_guy's Avatar
79_ford_400_guy
boring out a 400
hi, i have a 400 engine and it is in bad shape so im going through it and decided i want to bore it out i think i wanna go 40 over but not sure anyone have some advice????? if i do then about how much would it cost alltogether to get the job done? thanks kevin
Old Feb 12, 2002 | 09:42 PM
FastPony's Avatar
FastPony
boring out a 400
I just hade my 351w cleaned, bored out 40, new cam bearings, pistons put on rods, and new freeze plugs, for $210. Hope this helps.
Old Feb 12, 2002 | 10:08 PM
79_ford_400_guy
boring out a 400
does anyone else know bout what it costs for just broing it out
???????? thanks kevin
Old Feb 12, 2002 | 10:20 PM
Franklin2's Avatar
Franklin2
boring out a 400
You need to talk to a local machine shop that will do the work. You can take it to them, and they may be able to guess how much it will need to be bored. If one of the cylinders happens to be damaged, you may not be able to save the block(rare cases). What I am saying is, you just don't know till you take it to somebody to measure it. When you get it bored, they will bore it the least amount required to clean up the cylinder. You want the wall as thick as possible. They will probably want you to order pistons before they get to far into the job. Pistons will vary a little bit, and they will size the bore to match the pistons you buy.
Old Feb 13, 2002 | 04:47 PM
Bill_Beyer's Avatar
Bill_Beyer
boring out a 400
>out
My local (Vancouver, WA) machine shop charged me $120 for boring my 400 +.020. I also had them hot tank it for $39 before it was bored.
Old Feb 13, 2002 | 05:10 PM
Vampiro's Avatar
Vampiro
boring out a 400
andy 1979
18
Dec 7, 2010 09:44 PM
countryboy6074
Exhaust Systems
13
Jun 2, 2009 02:35 PM
4wheeling79
Sep 23, 2005 08:54 PM
crossbeed_65
18
Apr 22, 2004 08:17 AM
teamwizard
Mar 31, 2002 12:15 AM
