2006 F250 Order Opinion
Before anybody has a coronary, I plan to use the truck as a daily driver (to replace my 1990 F150), which 3-4 times a year tows my 65 Mustang (total weight with trailer is 5,800 lbs) and haul up to 500 lbs about 6 times a year for my do-it-yourself projects. The reason for the F250 and not the F150 is due to the poor transmissions, balljoints, brakes and i think it is a better looking truck- I drive in a very sporty manner, most is freeway driving in SoCal.
Here's what I'm looking at....
F250 regular cab 2x4, XLT
5.4 automatic
Handling package
Myself- remove the fan/clutch assembly and replace with an electric unit
Dealer- Install 3.25:1 differential gears
BellTech 3" lowering all 4 corners
Drop the mufflers and run twin pipes from the cat's straight our the back
Superchips mod
I'm figuring the mods & power (torque) at 25 mph + should be more than adequate to accellerate up to 75 mph and with the mods I should get 23-25 miles to the gallon (without the AC on).
I basically did the same thing (except change diff gears to my wifes 97 cougar sport 4.6 and we can get up to 27 mpg)
Thanks in advance.
5.4 automatic
Handling package
Superchips mod
Thanks in advance.
Originally Posted by Beechkid
FYI,
I've talked to two F250 owners (2004), both with the 5.4....one auto and one with the 6speed, the auto gets 18 mpg and the stick gets just shy of 20 mpg. That's why I'm thinking with the mods I should be able to get 23-25 mpg (on a good day)
If it's fuel economy that is important to you, the Ranger is the way to go but you won't be able to tow much with it as I'm certain you already know and even then you "might" get 23-25 mpg.
300cid? You mean the 300 I6? One of the most efficient, simplest engines Ford ever made?
The truck's going to look like crap dropped 3 inches (my opinion).
The modular engines are rev-happy... drop the gearing to 3.25 and you're going to strain the hell out of the drivetrain and put the engine way outside of its powerband.
You get 27mpg in the wife's Cougar... a car that weighs easily half of what a Super Duty does and has a miniscule coefficient of drag compared to an SD (a giant box on wheels)... and you want to get 75% of the gas mileage? And driving in the SoCal traffic, especially in a "sporty" (read heavy right foot) manner?
If you want good fuel economy, buy a small car. If you want a truck, buy a Super Duty. But don't expect a good truck with the fuel economy of a small car.
Can you get 3.25:1 gears for the rear end? Mine come stock with 3.73:1 which was the standard ratio. As I recall it was also the tallest setup you could get. Options were all geared lower, 4.10:1 if I remember correctly. I think the newer ones may be geared even lower.
I don't intend to be argumentative, but I have a real problem believing that you or anyone else will get anywhere close to 20mpg with a 5.4L V8 in a Superduty. I know my diesel won't do it. I get 14mpg +/- in mixed driving and 17-18 mpg highway driving for extended periods with cruise control. I'm certain that the 5.4L won't come close to matching this.
That 4x4 auto extended cab that can get 15 mpg is an F-150. Same goes for your current truck. Big, big difference between that and a Superduty. The F-250 is not a heavier sprung F-150. It's a mcuh larger and heavier truck.
If you can get 20mpg out of the V8 in an F-250, mcuh less 23-25mpg, please let us know about it. There are many folks on here, including me, that would be very interested in knowing how you did it. Good luck and let us know how it turns out.
is this thread even serious?? the electric fan swap will net you almost nothing but a loss of cash. the 3.25 gears are a bad idea. it moves the engine way out of its power band so you will make it less efficient. the 3'' lowering, i have no comment on. do not for a single second think you will get 25 mpg in that truck. more like 13 in town. 25 mpg is just not happening.
