Do you have door problems?
Old Nov 26, 2005 | 08:53 PM
Franklin2's Avatar
Franklin2
Hey I found out something. I posted a few days ago about my attempts at frame repair.
https://www.ford-trucks.com/forums/s...d.php?t=432615
In one of the pictures you can see the crossmember where the rear cab mounts sit is eaten away under the mount. The junkyard truck had both areas eaten away. Well I got a nice surprise today when I took off the trash after getting it all back together.
I always had a problem with the driver's door, which didn't seem to want to shut correctly, and was always making a "banging" noise in the latch area when I went over bumps in my driveway and especially on wash-board dirt roads.
When I re-installed the crossmember after painting it, I put two large pieces of metal across the hole to support the body mount. Now no more door banging! And the door shuts so much nicer now. It's hard to believe I have been driving around for so many years, and the driver's side rear cab has had no support at all.
Old Nov 27, 2005 | 12:49 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You can sure tell the frame on your truck is a 1980. 1980 and 1981 have all the holes like that in the side rails.
Thanks for the tip. It looks like the rubber mount held water over the support and "drilled" a perfect hole in there with rust. Is that correct? Interesting that.
Old Nov 27, 2005 | 02:37 PM
Franklin2's Avatar
Franklin2
Yes, you have to look twice since the hole is almost prefectly round. Then you realize the hole is the same size as the rubber mount. Now that can't be right.
Old Nov 27, 2005 | 03:15 PM
1981 f150's Avatar
1981 f150
I beg to differ here a little,my truck 1981 f150 custom, we bought brand new,actually we ordered it was built in June of 1981 and DOES NOT have all the holes in the frame (swiss cheese frame).
The frame in other words,has no swiss cheese holes in it,I have heard of this type of frame but do not see it on my f150.
Old Nov 28, 2005 | 04:43 AM
81-F-150-Explorer
That has to do with production dates. Not all of the 1981's have the "swiss cheese frame", but alot of them do though. Just like not all of the 1981's have slide lock controls, or clear turn signal lenses in the front like the 1980 but alot of them do.
Significant production changes to the 81 model happened in 11/80, 3/81, etc... and there were probably more that I'm not aware of too.
The funny thing, (or not so funny thing depending on your point of view, ), with all this, is I will go to the parts counter at Ford and ask for a part. Then they ask, was your truck built before or after 11/80? I will say it was built ON 11/80, and then after they thump their heads off the counter, they come back with two parts that look close to being the same but different enough that getting the wrong one wouldn't fit or work right for you. Then they ask, "Which one do you think looks right to you? "
