three gauge problems
Old Nov 26, 2005 | 12:16 AM
Cool1996's Avatar
Cool1996
i have a 1999 f250 diesel and i have a three gauge pod to mount abouve the rear view mirror with isspro pyrometer, boost, and trans temp gauges..SoOoOo what i need to know is. where do i put the trans temp sending unit? what should my boost reading be (boost gauge is hooked up and i saw 7psi max...that cant be right) and what should the pyrometer reading maximum be and what is a safe temp to shut it down....thanks alot guys
Old Nov 26, 2005 | 03:43 PM
Franklin2's Avatar
Franklin2
I don't know what the boost should be. I would go up to one of the Diesel forums and ask. They probably know. As far as mounting the temp sending unit for the tranny, I went to the isspro link, and they sell an aluminum tranny oil pan that has the place for the sending unit.
Old Dec 1, 2005 | 08:41 PM
UnderTakr's Avatar
UnderTakr
The tranny sending unit you can just screw into the Test Port on the front of the tranny. Its a 1/4 screw just above the 2nd pan bolt on the drivers side!!
Jeff
