distributor
Old Nov 26, 2005 | 12:01 AM
jj22ee's Avatar
jj22ee
distributor
Hey guys jsut wanted your opinions on what distributor to run in my 73 f100 with a 390 just trying to get my parts ordered for my restoration? I have single point dist. would like to go efi maybe accell or msd let me know your opinions. Alos wht is the best timing set and oil pump?
Old Nov 26, 2005 | 01:06 AM
gtex's Avatar
gtex
What's your budget?
I run the MSD billet distributor, MSD 6al ignition and an MSD coil. It works fine.
if I had it to do again, I'd run a Peformance Distributor DUI setup. ( http://www.performancedistributors.com/ ) simpler, less clutter.
If you want something more affordable, just get a duraspark setup for a later model FE.
As for oil pump, most of us run the melling high volume pump, HV57
Timing sets: I'm not sure there's even a popular choice here. I run the edelbrock, but I suspect most any name brand true-roller setup would do fine.
Old Nov 26, 2005 | 01:08 AM
gtex's Avatar
gtex
Looks like the Edelbrock is a Cloyes. both solid names. if you can get the Cloyes cheaper go with that.
http://www.edelbrock.com/automotive_...g_chains.shtml
Old Nov 26, 2005 | 07:51 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
By far the best timing sets are the Rollmaster sets. Billet heat treated gears and German seamless double roller chain. $100.
G.
