292 Carb trouble
Old Nov 25, 2005 | 10:24 PM
stil190's Avatar
stil190
292 Carb trouble
Hi,
I have recently put in a replacement engine in my 64 F600. Runs fine but will not start without putting some gas in the carb. I am thinking that a accelerator pump may be the issue. So planning to rebuild my carb. However have never done this before. Can anyone provide any suggestions or ideas to a rookie?
Thanks
Old Nov 26, 2005 | 05:43 AM
Col Flashman's Avatar
Col Flashman
Cheque that, but also cheque your Petrol Pump as well.
Old Nov 26, 2005 | 07:56 AM
57_ford's Avatar
57_ford
That kind of carb? 2bbl motorcraft? Just a guess I think the gas is leaking out of the carb into the engine when it is shut off. Maybe a power valve or something.
Old Nov 26, 2005 | 08:01 AM
stil190's Avatar
stil190
It is a 2bbl FoMoCo. I have a rebuild kit coming in today. Should be fun.
Old Nov 26, 2005 | 08:07 AM
57_ford's Avatar
57_ford
Just take your time you should be ok. Watch how every thing comes apart. Take pictures I find that helps me alot.
Old Nov 26, 2005 | 10:10 AM
1952henry's Avatar
1952henry
The kit will (should) have an exploded view. Study your carb against the pictures to get familiar with the outside. Your work area should be clean and clear from clutter. Try to lay things out in groups as you dissemble. They're not very complicated. You'll do fine.
Old Nov 26, 2005 | 10:27 AM
1952henry's Avatar
1952henry
Oh, one other thing; before final assembly, check all housing components on a flat surface. If there is any warpage, place a piece of sandpaper on the flat surface and sand the piece flat. Finally, don't overtighten the screws, this will only cause more warpage.
Old Nov 26, 2005 | 02:34 PM
fking1's Avatar
fking1
Had the same problem with my rebuilt Y-Block. Turned out there were metal shavings in the carb needle valve. Probably from the overhaul machining and not cleaned well. Cleaned it and it ran like a champ.
Carb rebuild is not hard, having said that I took mine to a cab specialty shop for the rebuild.
Fred
Old Nov 26, 2005 | 03:58 PM
286merc's Avatar
286merc
With carb shops charging $75 and up for a 2bbl these days it makes sense to at least try it yourself.
Get a quality kit such as NAPA. Rust particles are a usual cause of problems but that also means pay attention to the complete fuel system right back to the tank. Otherwise you will be just doing it over again. Install an in line fuel filter, again a quality one.
Old Nov 27, 2005 | 09:16 AM
stil190's Avatar
stil190
Well I picked up the NAPA rebuild kit. It does include an instruction sheet with a diagram. A little background. This truck had been in storage for about 15 years. So I have removed the fuel tank and cleaned it. Also the fuel line had to be replaced since it was plugged. At that time, I installed an inline fuel filter. So I am hoping that with this rebuild the problem should be gone.
The next project for me will be the brakes (only the parking brake works at this time). The booster (located under the driver floor board) was also bad. I am afraid that my bleeders and wheel cyclinders may not be good. So this could be a big job.
Thanks for all the input.
Old Nov 27, 2005 | 03:06 PM
fking1's Avatar
fking1
Check out NAPA for brake parts too. got most of mine there.
Fred
