Bronco II Ford Bronco II
4x4 shift motor
Old Nov 25, 2005 | 09:17 PM
bIIcool's Avatar
bIIcool
4x4 shift motor
I just removed my 4x shift motor on my 90 bronco II cleaned the contacts and reinstalled it. Now my 4 Hi works every time but my 4 low sometimes it works and other times it acts like the transmission is in neutral. Is this a mounting issue?
Old Nov 26, 2005 | 10:35 AM
Monty06's Avatar
Monty06
what did you clean it with first question. and second question is wiring any splice or dice.
Old Nov 26, 2005 | 01:54 PM
bIIcool's Avatar
bIIcool
I did not splice any wires I removed them from the connector, I did make sure they were clean before I reinserted them into the connector. I used fine emery cloth to clean the contacts then cleaned it with contact cleaner.
