radiator hose ???????
Old Nov 25, 2005 | 06:26 PM
75fordkid's Avatar
75fordkid
I cant seem to find a radiator hose which will fit my 75 hiboy. The truck had a 390 and now has a 460. The hose off of my 390 would work if it wasnt for my 3 inch body lift which makes the hose hit on the power steering belt. So im looking for any suggestions before about finding the rite hose, otherwise i am thinking of just moving the radiator down 3 inches but this is kind of a last resort thing. ANY IDEAS?????
Old Nov 25, 2005 | 08:00 PM
ivanribic's Avatar
ivanribic
Measure what you need and go to Napa. They'll sell you a flexible hose at any length up to 30" I believe, with the wire inside to keep it from collapsing.
Old Nov 25, 2005 | 09:52 PM
75fordkid's Avatar
75fordkid
lol funny you say that i was at napa for over an hour today. I know the flexable hose your talkin about but im not sure if it will bent as sharp as i need it to. Plus it would suck to replace my ps belt because is running rite thru the belt form the pump to the radiator
Old Nov 25, 2005 | 11:36 PM
ivanribic's Avatar
ivanribic
Yikes! One more reason I hate body lifts. Your best option may be to drop the radiator but that's gonna take a little work too. I think you should try getting that flex hose though and see if it'll work and clear everything. It'll run about $28-$35 if I remember right. If it doesn't work and it's not "used" you can take it back for a refund. They bend fairly well. It's too dark to take a picture now but I have a fair bend in the hose I'm using.
Old Nov 26, 2005 | 01:28 AM
ford390gashog's Avatar
ford390gashog
drop the radiator down.
Old Nov 26, 2005 | 01:31 AM
75fordkid's Avatar
75fordkid
ok well ill try the flex hose first otherwise ill just drop the radiator. all ill have to do is drill new holes and bolt it in rite??
Old Nov 26, 2005 | 01:32 AM
ford390gashog
yes 4 new holes and drop it down.
Old Nov 26, 2005 | 06:52 AM
User 71024's Avatar
User 71024
I don't like flex hoses, they are too hard and beat on the radiator fitting causing failure. If it's just a length problem, buy a piece of copper pipe the sizoe of the hose and cut the hose and clamp the pipe in as an extension. I usually solder a ridge on the ends of the copper pipe so the hose clamp has something to grip.
