No heat 97 Explorer
Old Nov 25, 2005 | 06:12 PM
sc4x4's Avatar
sc4x4
No heat 97 Explorer
Drove my wifes Explorer today ( 97 model) and there was minnimal heat coming out the vents. I turn the heat selector from hot to cold and I get pure cold air, turn it back to hot and the air warms up but not like it should be. I figured I had the wonderful blend door problem, I could tell a definete difrence in temp from hot to cold so can I assume the blend door is working? Does a heater core go bad without leaking? All the heater cores I have replaced I replaced because of leaks. Could the thermostat be stuck open not letting the engine warm up enough? The explorer has the 5.0. Any thoughts would be appreciated.
Thanks,
Jeff
Old Nov 25, 2005 | 06:59 PM
vicv's Avatar
vicv
Could be the blend door is broken and hanging up before full heat. But check the easy stuff first-coolant level, t-stat, heater control valve. If you haven't replaced these things since you got the truck it won't hurt to do it now. Then think heater core-flush thru from both sides. Then I'd think blend door actuator motor and blend door.
Old Nov 25, 2005 | 07:40 PM
87 XLT's Avatar
87 XLT
Like vivc sez it could be lots of things. Is the temp gauge running where it always has? Are the heater hoses too hot to handle? If not is the heat valve in the hose working.
Old Nov 27, 2005 | 12:34 AM
texan2004's Avatar
texan2004
Blend door problem is easy enough to check with a mirror.
Old Nov 27, 2005 | 04:17 AM
sc4x4's Avatar
sc4x4
Thanks for the info everyone. It was the tstat, I pulled the housing and the tsat was in 3 pieces. I intended to replace it and the hoses and belt when I bought the explorer a few months ago just never had time. Now the wifes winter beater is ready to go.
Thanks,
Jeff
Old Nov 27, 2005 | 05:58 AM
marragtop's Avatar
marragtop
Good think it stuck open and not closed....
Old Nov 27, 2005 | 11:15 AM
texan2004's Avatar
texan2004
Good thing it wasn't a broken blend door. Glad you got it.
mlelah
26
Jan 10, 2015 02:27 PM
MD79TA
Jan 4, 2015 06:08 PM
HMAN1055
13
Dec 15, 2014 11:44 AM
yooper5.4
Jan 8, 2014 12:03 PM
baileymoeracing
Jan 4, 2012 07:36 PM
