New guy
Old Nov 24, 2005 | 12:09 AM
Fred_M_89_F150's Avatar
Fred_M_89_F150
New guy
OK, I just joined up. I'm gonna need more help than I can give. 89' F-150 in-line 6 2WD manual w/220,000 miles. 2 problems- 1st No headlights (parking, tailights, turn signals, all good, but no headlights. Can't be the bulbs- both at once? There's only a fuse for headlight switch- I'll see if someone can help me with this first as it's an emergency for me.
Old Nov 24, 2005 | 02:00 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Nov 24, 2005 | 11:16 PM
Franklin2's Avatar
Franklin2
It could be the dimmer switch. Do you have a testlight or voltmeter to do a little testing?
Old Nov 25, 2005 | 01:50 AM
Bdox's Avatar
Bdox
Did you check both high and low beams?
Old Nov 25, 2005 | 10:08 AM
Fred_M_89_F150
I get high beams if I tap the dimmer switch (the high beam/low beam switch on the floor) but the low beams are out.
Old Nov 25, 2005 | 10:19 AM
Fred_M_89_F150
I do, but I've no experience in tracking down electrical problems. I think I might just replace that dimmer switch, to start- I'm headed to parts store.
Old Nov 25, 2005 | 12:03 PM
Franklin2's Avatar
Franklin2
If that doesn't fix it, write back in and we can help you use that meter or testlight.
Old Nov 25, 2005 | 10:44 PM
Fred_M_89_F150
Will do, and thanks for the help.
