Sponsored by: Real Truck
charging light
Old Nov 23, 2005 | 07:25 PM
Sundance Kid's Avatar
Sundance Kid
charging light
I have a 99, F350 that the charging light keeps flickering with lights on or off. The guage doesn't fluxuate and I've tested the alternator and battery.( this was done still in the truck.) Both checked good by local mechanic. Doe's anyone have an idea what to do next. Thanks
Old Nov 23, 2005 | 07:37 PM
99f350sd's Avatar
99f350sd
Ist check wires at the alt, the flat connector pull it off and check it..Most likely you need a new regulator if its the original alt. You can buy a new brush kit with reg and install it yourself if you want to. Just pull the alt and remove a few screws its real easy.
Dick
Old Nov 28, 2005 | 06:43 PM
estimator's Avatar
estimator
I Had To Replace My Battery And Alternator. The Battery Was Not Holding Charge, And The Alternator Wore Out Charging All The Time.
Conclusion: If The Battery Is Five Years Old, Buy A New One Before Alternator Failure
