Just found this site,looks like a good one so will ask a question, has anyone put in some sound deadening material in thier Escape, if so where and did it help,I find my Escape kinda noisy, 2001 XLT.
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Ford added something to the 05 Escapes to reduce noice but the 01-04 Escapes are noisier. I've heard of people spraying undercoating and adding dynamat but it hasn't helped much.
I reduced a lot of noise in my 02 when I switched tires. I don't drive offroad or in snow so put on a decent set of highway tires. This may not be an option for you but offroad and a/t tires make a lot of noise.
My 05 isn't as noisy but I can't see they've added anything underneath (undercoating). I know one issue in the 01-04 was wind noise. My 05 has various rubber/foam pieces between the door and body which I assume was to reduce road noise.
