self test wont start
Old Nov 23, 2005 | 12:54 PM
goatee's Avatar
goatee
I have a 1998 explorer with eatc. When i try to do the self test (hold floor and off at the same time then within two seconds press auto) it does nothing. Is this not the right test for my vehicle?
Old Nov 23, 2005 | 02:16 PM
87 XLT's Avatar
87 XLT
If this is wired the same as a 97 theres a grand total of 7 fuses you should check. Interior fuses 6/9/10/18/31. And under the hood in the PDB fuse 9.
Amazing the amount of tecnology it takes to blow air thru a couple of vents.
Maybe it's not going into self test because of a blown fuse.
Whats the problem with it?
Old Nov 23, 2005 | 04:05 PM
goatee's Avatar
goatee
Thanks Ill check those. I looked in the owners manual but didn't realize it didn't do all of those. The problem is Im trying to run down the blend door issue. Ours will not blow cold air went set on VENT only hot. I checked my actuator motor and it doesn't move so Im trying to make sure before I replace it.
Old Nov 23, 2005 | 04:15 PM
goatee's Avatar
goatee
Well checked em, they all appear good. I actually just checked every one.
Old Nov 23, 2005 | 04:41 PM
goatee's Avatar
goatee
Ok well I pulled every fuse with the battery disconnected. Reconnected the battery and everything works great now. I still cant do the test though.
Old Nov 24, 2005 | 02:41 AM
87 XLT's Avatar
87 XLT
Well, I thought i might be able to find some info that would help you with this, but did'nt have much luck.
This link-www.coolcats.net/tech/troubleshooting/atc.html- is for the climate control on a 97 Cougar & might be helpful if yours works the same.
I see it has a different method for putting the system in self test mode that you might want to try. If it works & you get a code 5 the blend door actuator is the problem.
Or maybe the system just needed to be "rebooted" & disconnecting the battery took care of it.
It would sure be handy if you could take a look at the pinpoint tests in the Ford factory shop manual
Good luck with it.
Old Nov 24, 2005 | 10:13 AM
goatee's Avatar
goatee
Yeah we need a manual sometime probably. Ill check that other one out. For now anyway, I gues it doesn't matter.
