Roller Rocker Lifespan
Old Nov 22, 2005 | 10:49 AM
frankalonge's Avatar
frankalonge
I am rebuilding the 400 in my '79 f250. When we rebuilt the engine last, about 70K miles ago, we put a set of Motorsport roller rockers in it. It was a mild build with a slightly bigger cam and stiffer valve springs. Nothing has failed in the engine. The pedastals all look good, no wear issues in the rockers. My question is what is considered a normal lifespan for aluminum roller rockers? Is there any reason not to put them back into the engine?
Old Nov 22, 2005 | 11:42 AM
53fatfndr's Avatar
53fatfndr
If it were my engine, I would put them back in. "No wear issues", I don't see any problems.
Old Nov 22, 2005 | 11:51 AM
monsterbaby's Avatar
monsterbaby
I don't see any problem with reinstall them just check the rollers both the tip, and trunion for looseness and if no slop run them. On a mild build they will last every bit as long as a stamped steel rocker under normal circumstances.
Old Nov 23, 2005 | 01:22 AM
74 F100 351m's Avatar
74 F100 351m
I have run mine hard for 9 years.
85lebaront2
Mar 12, 2014 05:51 PM
hunnterr4
Apr 15, 2013 03:41 PM
yellow72f100
Jul 22, 2008 08:20 AM
Huntersbo
Sep 24, 2005 07:28 PM
mcguyver
Aug 31, 2002 08:23 PM
