Twin throttle body windsor
Old Nov 22, 2005 | 03:29 AM
Xalent's Avatar
Xalent
Hello,
Can anyone tell me what model Fords came out with the twin efi throttle body version of the 351 Windsor? Also does anyone know whether they are MAP or MAF?
Thanks
Greg
Old Nov 22, 2005 | 08:57 AM
Kemicalburns's Avatar
Kemicalburns
88-96 for efi 5.8
maf some 94's cali only most 95's and all 96's but those were obd-II and not the better efi setup. go here www.fordfuelinjection.com
Old Nov 22, 2005 | 10:59 AM
frederic's Avatar
frederic
add 97 to that year range. The 97 F250/350 had the 5.8L as an option.
Also, the dual throttle body on the 5.8L is the same as on the 460, from 88-97 as well.
Old Nov 22, 2005 | 11:17 AM
loudfords's Avatar
loudfords
The dual throttle body is also the same as the 5.0 truck throttle body.
Old Nov 22, 2005 | 04:46 PM
Xalent's Avatar
Xalent
Thanks guys. I'm trying to ID an engine but it didn't come with any pipework or MAF sensor after throttle bodies, and also didn't come with a MAP sensor. I've got the computer code but fordfuelinjection doesn't have a listing for it. It is EEC-IV EFI-SD48B U2L1
Can anyone shede some more light on this? I really need to know what year it is to track down a wiring diagram and some of the missing pieces....
Cheers
Old Nov 22, 2005 | 06:57 PM
EPNCSU2006's Avatar
EPNCSU2006
It is a speed density computer. If it were mass air, it would start with SEFI-MA___.
Old Nov 22, 2005 | 10:04 PM
Xalent's Avatar
Xalent
Thanks. So I guess I have to track down a MAP sensor. Are they all the same i.e will a 5 litre MAP work? Also will it require a barometric pressure sensor?
I'm in Australia and theres not too many of these around that I can check out!
Cheers
Old Nov 23, 2005 | 06:43 AM
EPNCSU2006's Avatar
EPNCSU2006
It will use just a MAP, not a BAP and MAP. As far as I know, any Ford MAP sensor from about the same year model will work. You can cross reference Ford parts on www.motorcraft.com to make sure.
bwolf09
Nov 26, 2016 07:07 PM
KevGun8994
Nov 13, 2012 10:13 AM
mweeps
1978 - 1996 Big Bronco
May 22, 2003 01:33 PM
red ranger
Nov 10, 2002 09:19 PM
cow_rancher
Aug 15, 2001 06:42 PM
