Engine mods required with EGR removed.
What should I do now regarding the timing and stock distributor that, at present, are set to EGR operating specs? I have read on this forum about changing the springs and weights in the distributor, but it seems as though that is pretty much a hit or miss solution. Is there an aftermarket vacuum advance distributor that will work well with the non-EGR stock engine? And if so, what what would be ideal timing numbers for the non-EGR setup? Any other suggestions?
http://cgi.ebay.com/ebaymotors/50K-429-460-351C-351M-Ford-HEI-Distributor-3yr_W0QQcmdZViewItemQQcategoryZ33690QQitemZ8016321 926QQrdZ1QQsspagenameZWDVW
I've heard fairly good reviews of this particular distributor with vacuum advance.
Anyone have good or bad experiences with these? I'm not quite sure what the difference is between these generic units and the $300 MSD units.
Better yet, here's a whole kit from mad dog:
http://cgi.ebay.com/ebaymotors/Ford-...temZ8015037836
http://cgi.ebay.com/ebaymotors/Ford-351c-460-pro-billet-distributor-6AL-box-coil-si_W0QQcmdZViewItemQQcategoryZ33690QQitemZ80150378 36
Do these distributors connect to the stock "computer" control module located on the driver's side wheel housing? Or do the HEI distributors operate independent of the module and thus, the stock control module can be eliminated along with the stock coil?
For the first link (just the distributor), search for item # 8015428565
For the complete kit, search for item # 8015037836
Let me know what you think...I'm trying to decide whether to buy the kit...
I am essentually just trying to compensate for the removal of both the EGR and AIR systems from the engine and produce the best compromise between performance and fuel economy.
