Aerostar Ford Aerostar
Bolt Size
Old Nov 21, 2005 | 01:56 PM
wtroger's Avatar
wtroger
Bolt Size
On a 4.0 liter 1992 Aerostar does anyone know what size the drilled and tapped holes are in the harmonic balancer. I need to know so I can pull it off to fix a coolant leak between the timing cover and the block
Old Nov 21, 2005 | 10:07 PM
copper_90680's Avatar
copper_90680
Either a 5/16" or an 8mm. I think either would fit since the thread pitches and diameter are so close to each other.
Old Nov 22, 2005 | 10:19 PM
99f350sd's Avatar
99f350sd
Not close enough to fit.
Old Nov 23, 2005 | 08:54 PM
cbr900's Avatar
cbr900
it has to be 8mm as all bolt's and nut's and are metric.
