'64 Generator Terminals.
Old Nov 21, 2005 | 11:32 AM
jethro1's Avatar
jethro1
The '64 generator has two nut-fastening terminals next to each other on the generator body. One is the "ground" and the other the "field" terminal. Without out referring to the incoming wires from the regulator, how do you tell which one is which?
Old Nov 22, 2005 | 10:02 AM
dendyr's Avatar
dendyr
Take a volt tester and ground one lead to the body of the generator and then test your terminals. That will tell you which one is your ground. Hope this helps.
Old Nov 22, 2005 | 05:31 PM
berkad's Avatar
berkad
In case you do not have a meter. Looking from the front of the generator (pulley facing you) and the terminals on top. Ground is to the right. Meaning the one to the right reads zero ohms and the one to the left reads around .084 ohms. Check the manual for proper connection. there are other posts here about installing a new generator.
Old Nov 23, 2005 | 06:46 AM
jethro1's Avatar
jethro1
Thanks, berkad. That's the kind of shade-tree advice I was looking for. I'll check the other posts. Thanks.
