headlights cutting out
Old Nov 21, 2005 | 10:01 AM
Caleb1's Avatar
Caleb1
Every once inna while while I am driving, the headlights start cutting on and off. it used to take about ahour of driving, but now it seems to do it sooner and sooner. it seems that if I pull over and turn them off a few minutes, then I can drive a pretty good distance before it;s a problem again. I was thinking dimmer switch. How hard is that to replace? any other ideas? thanks a lot!
Old Nov 21, 2005 | 05:02 PM
Franklin2's Avatar
Franklin2
It's usually the headlight switch. It has a circuit breaker in it that is tripping and then reseting. The problem is a loose connection at the switch plug, which melts the plug and the wiring. Get a new headlight switch and make sure the plug and the wiring are not burnt up at the headlight switch. Someone on here said you can get a replacement plug from Ford for some models.
Old Nov 22, 2005 | 09:16 AM
Caleb1's Avatar
Caleb1
Thanks! i'll check it out
