Replacing Shocks
Old Nov 21, 2005 | 08:34 AM
BlueOval5.0's Avatar
BlueOval5.0
Replacing Shocks
I searched this forum for some suggestions on replacing the shocks on my '98 XLT AWD with 80k on the clock. The truck seems to bottom out over bumps now.
It seems the most popular shock is the Monroe so I'll go with those.
As far as installation is concerned, I'm kind of a novice at this kind of stuff but am going to try to do it myself. From what I've read here, it doesn't seem overly difficult. Should I take the wheels off to make the job easier? What about dropping the spare, is it necessary?
Any suggestions on spraying some type of penetrant on the rusted bolts?
Thanks,
Eric
Old Nov 21, 2005 | 07:56 PM
bulldog3531's Avatar
bulldog3531
Spray WD40 or something of that nature the day before let it soak real well.Dropping the spare is not necessary but gives you a more room to work with the upper bolts on the rear. Removing the fronts wheels will give you plenty of room and it is easier to work. Hope this helps you.
Old Nov 22, 2005 | 07:56 AM
ajguzik's Avatar
ajguzik
Do drop the spare
Drop the spare and spray all the nuts/bolts with a good penetrating oil. Shock replacement is pretty straight forward. I never removed the wheels to change mine.
Old Nov 26, 2005 | 07:22 PM
98xlt's Avatar
98xlt
Dropping the spare makes the rear ones much easier to change out. I also didn't remove the front wheels, although I did turn them hard to one side to create more access to the nuts.
Old Nov 26, 2005 | 07:38 PM
vicv's Avatar
vicv
I removed the front wheels and dropped the spare. Since I'm poking around in there already I like to look around at the stuff I don't normally get to see. Check the front brake pads, look for rubbing, rust, anything out of the ordinary.
Old Nov 26, 2005 | 08:45 PM
gman88's Avatar
gman88
Don't waste your time with WD40, use PB Blaster for your penetrating oil. I have used it to remove many rusted components on 20 year old rusted vehicles from Minnesota road salt. It has not let me down yet.
slowmans
6.4L Power Stroke Diesel
Oct 21, 2011 12:06 PM
SSG VA BEACH
Virginia Chapter
Nov 23, 2008 12:44 PM
zoti
1983 - 2012 Ranger & B-Series
29
Apr 23, 2004 09:25 AM
cribbej
Oct 17, 2003 08:03 PM
alpo23
1978 - 1996 Big Bronco
Apr 3, 2003 11:13 AM
