Can someone help me out installing this HU. I think it's an Aiwa, I can't tell the faceplate is a little scratched, but it works great, at least it did in my other truck. Now it won't turn on. I'm pretty sure I got the wiring right. Anyway, If someone has any ideas what's wrong with this thing, let me know.
Here's a pic, if it helps any.
did you bench test it b4 installing it?
if so and it did work
start by checking your fuses
if that checks out-- i would get out a multimeter
and check your three primary power wires
one ground wire
one constant 12v+
one switched 12v+(with key on)
often times there are fuses in the power wires going to
the aftermarket head units or right on the back of the unit
itself
g/l
