Sponsored by: Real Truck
Block heater...?
Old Nov 20, 2005 | 03:35 PM
Bowcop's Avatar
Bowcop
Block heater...?
My block heater has stopped working and I can't figure out why??? It is getting juice but won't work...........
Any ideas as to why it went out. I can't imagine that the element is dead...??
It is in a 01 250 5.4.
Thanks all
Any idea how much to replace it? It looks like a very tight squeeze up in there>!!!!
Old Nov 20, 2005 | 04:45 PM
mhoefer's Avatar
mhoefer
double check the cord is plugged into the heater on the side of the block properly, check the whole wire for a short. It culd have been wearing against something. You might have to replace just the cord. f its the actual block heater, thats a bit more expensive.
Old Nov 20, 2005 | 06:55 PM
Bowcop's Avatar
Bowcop
Ok I did all of that and everything is in order..............?
Old Nov 20, 2005 | 08:01 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Have you checked with an ohm meter to see if you have continuity. Also can you check it with an amp meter to see if there is any current draw.
Old Nov 20, 2005 | 08:07 PM
Bowcop's Avatar
Bowcop
No,
I don't have one of those meters.......
It seems to be working but sporadically. Not sure what is going on here!?!?!?!
Old Nov 20, 2005 | 08:11 PM
bigredtruckmi
Veteran: Navy
This sounds like it might not be making connection from the cord to the block heater or your extension cord might be going bad ( I had this happen)
Old Nov 20, 2005 | 10:17 PM
Bowcop's Avatar
Bowcop
I thought about that too.... I have tried several differant cords and it seems to do it on all the cords, I think I might have to replace it.
