1964 differential
Old Nov 20, 2005 | 11:55 AM
toolman79706's Avatar
toolman79706
Question 1964 differential
what type diff. did the 64 ford f100 come with mine is a 10 bolt tapered axles 35 /9 gears looks solid but must be limited slip???
Old Nov 20, 2005 | 02:50 PM
barry's Avatar
barry
If the center section comes out the front, it's a Ford 9 inch rear. If it has a cover on the back, it's a Dana 44 axle. Post the axle code on the door or the tag info if it's still on the rear end, we can decipher it for you.
Barry
Old Nov 20, 2005 | 03:50 PM
toolman79706
toolman tag says WBG could be W8 C WBG_F2 3.69 3jb 301
35 tooth ring 9 tooth pinion 10 bolts to remove front 28 spline axles
and a whole lot of black tar grease!!! thanks
Old Nov 20, 2005 | 05:16 PM
barry's Avatar
barry
The ratio is right in what you posted, 3.69 , non-posi. It's a 9 inch Ford housing. Sounds like it's time to change that nasty fluid.
Barry
