Back-Up Lights:
Old Feb 28, 2002 | 03:39 PM
leonharu's Avatar
leonharu
Back-Up Lights:
I noticed the back-up lights don't come on sometimes unless I jiggle the shifter and they still do not stay on sometimes.Is there a switch to adjust and where is it?The truck is a 1973 F-100 with 360 engine automatic C-6.Anybody had this problem?
Thanks,Russell
Old Feb 28, 2002 | 04:17 PM
79f3504x4's Avatar
79f3504x4
Back-Up Lights:
Switch on lower part of column needs adjusted or replaced.Called neutral safety switch,also works reverse lights
Old Mar 1, 2002 | 03:03 PM
hartmark's Avatar
hartmark
Back-Up Lights:
My '74 has the same problem, but I hadn't gotten around to fixing it, as there are lots of other problems I need to care for first. Speaking of lights, has anyone had a problem with the brake lights staying on? There is about 1/4 inch of slack space at the top of the pedal travel that is not taken up by the spring in the pivot (uh, I'm assuming there is a spring... is there?). I have already adjusted the switch to its fullest extent, but no dice. They do go off if I pull up on the pedal, or when the battery goes flat.
Any clues???
Thanks
Old Mar 1, 2002 | 07:01 PM
tbirdrief's Avatar
tbirdrief
Back-Up Lights:
I also had this problem,and my switch must have been worn to the point that I couldn't adjust it.
I took the switch off, took a piece of hard plastic hose cut it about 1/4 to 3/8 long( the length of the switch post),split the hose so that it slipped over the switch post. Reinstalled and adjusted it.
Make sure that the shifter arm is on the correct side of the switch post or it won't work.
And without question make sure that it won't start in gear.
Good luck,
Jeff
Old Mar 1, 2002 | 09:32 PM
Bobbygullotto's Avatar
Bobbygullotto
Back-Up Lights:
Old Jan 27, 2006 | 07:30 PM
lukesullivan's Avatar
lukesullivan
hartmark
The problem you face is a leaking booster.
Luke
Old Jan 27, 2006 | 07:31 PM
lukesullivan
replace the booster.
Any clues???
Thanks
Old Jan 28, 2006 | 06:58 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
WOW this is an old thread...however you like to help so jump into the forums and start posting....We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 28, 2006 | 05:19 PM
shticky's Avatar
shticky
I have a 1978 F150 Lariat with the same problem. No reverse lights. Any suggestions?
Old Jan 28, 2006 | 07:59 PM
woodysford's Avatar
woodysford
where exactly is the neutral saftey switch?
Old Jan 28, 2006 | 09:04 PM
Mil1ion's Avatar
Mil1ion
On automatics ,
In 1978 they moved it to the side of the transmission.
Before that it was mounted on the steering column.
On std trans it is located at the back of the transmission.
Shticky,
Remove it and clean it out with these in this order:
Varsol
Lacquer cleaner
Electrical cleaner
Blow it out with compressed air.
