No Brake Lights
Old Nov 20, 2005 | 08:31 AM
scotty8812's Avatar
scotty8812
No Brake Lights
I have a 1997 f - 150 5.4. The fuse that controls the brake on/off switch, rear anit-lock brake module, and brake pressure switch has been blowing. The first time it happened it took about 2 months for it to blow. I replaced it and this time it blew right away. I checked out some connections, tried it again and this time it held for about 2 days. I haven't noticed any trend from something I am doing or using or the weather. Any help is appreciated.
Old Nov 20, 2005 | 09:57 AM
projectSHO89's Avatar
projectSHO89
Most likely, a leaking cruise disconnect (brake pressure) switch.
When it shorts enough to blow the fuse, you loose all the circuits you mentioned.
At least your truck hasn't burned up - yet.
Folow up on the cruise recall threads for more information.
Steve
