No forward
Old Nov 20, 2005 | 12:01 AM
Joe Boz's Avatar
Joe Boz
No forward
I have a 1990 Supercab (4.9L, E40D tranny) that has no forward gears. Reverse works fine. Prior to the forward gears going out I was having fuse problems due to an aftermarket installed stereo. Is there any connection there? Any suggestions?
Old Nov 20, 2005 | 06:28 PM
rclarke's Avatar
rclarke
A mechanically ok E4OD will always have 2nd and 4th gear even with no electronics hooked up.
Old Jan 15, 2006 | 06:59 PM
Sluggo#1's Avatar
Sluggo#1
Arrow
Anyone have an experience like this, and what was the solution. Did I somehow end up with Joe's truck? I got a 90 supercab 4.9 e4od with the same problem, only it was like this when I got it. Plus I tried to pull the codes and got a continuous signal, codes not readable. I know I need to check all connections and grounds, but what else?
Old Jan 17, 2006 | 07:30 AM
Sluggo#1's Avatar
Sluggo#1
Arrow
Does anyone have anything to say about this? Would a tranny shop be just as foiled and just say to replace it?
Old Jan 18, 2006 | 03:40 PM
Sluggo#1's Avatar
Sluggo#1
bump this to the top, maybe someone has a clue.
Old Jan 18, 2006 | 05:48 PM
dkborg's Avatar
dkborg
Having the same problem with E4OD in 95 Bronco. Anyone have any suggestions?
Old Jan 20, 2006 | 02:50 PM
Sluggo#1's Avatar
Sluggo#1
Arrow
This makes sense. Does anyone have a second to this statement or other knowledge?
