General Automotive Discussion
Spark Plugs
Old Nov 19, 2005 | 09:49 PM
Mr.Ford 351W's Avatar
Mr.Ford 351W
Spark Plugs
1994 Bravada 4.3l W( vortec)
how hard is to remove the #3 plug?
Old Nov 20, 2005 | 08:49 AM
57_ford's Avatar
57_ford
Not sure, I think you may be able to get to it throu the wheel well. You may need to take off the wheel and the rubber flap. I needed to do this on a blazer.
Old Nov 20, 2005 | 03:37 PM
JD717's Avatar
JD717
You should NOT need to remove the wheel well, I did that once, then realised ALL too late that right by the front axle, is the rubber flap to access them through. there is one plug that I think is impossible to reach due to the steering column being in the way. I believe you have to tilt the engine to reach that one.
Old Nov 20, 2005 | 06:52 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
ive changed many, many of these and never had to do anything with the steering. i just put the sparkplug socket on it, then turned it with a wrench. not impossible.
