Ignition swap
Old Nov 19, 2005 | 07:23 PM
Bdox's Avatar
Bdox
Ignition swap
86 F150, 4x4, 4.9six, np435 Calif. vehicle
I am planning to go to an aftermarket carb. I have the "elec" carb now so I believe that I need to swap out my ignition to do the replacement carb. So here is my question. Should I use Duraspark II? If so, can one of you experienced guys tell me what part numbers to look for? Or should I use a different system? I just want something that works, I'm not trying to build a hotrod.
Thanks
Old Nov 21, 2005 | 08:09 PM
javi2001's Avatar
javi2001
Yes, any duraspark II for 1985 - 86 will fit. Remember some wiring is going to be necesary also.
Old Nov 21, 2005 | 09:06 PM
Bdox's Avatar
Bdox
Thanks javi, that's what I thought. Can you refer me to a source online for part numbers? I have a book with wiring diagrams so I'm ok there if Haynes is to be trusted.
If I buy a distributor and an ignition module is that all I need?
Old Nov 22, 2005 | 10:43 AM
Oscar Meier's Avatar
Oscar Meier
you also need the harness to connect the module to the dissy & coil. There isn't a duraspark II on the 85-86. That ignition was the TFI w/ eeciv control - i.e. you have the electric carb.
Old Nov 22, 2005 | 07:55 PM
javi2001's Avatar
javi2001
If you can addapt a TPS sensor at your new carb, you can still using TFI ignition, EEC computer and all the stuff; since in that computers, ignition control program runs as a separate program module
