92F150 open loop question
Old Nov 19, 2005 | 05:16 PM
Pacerguyel2's Avatar
Pacerguyel2
Question 92F150 open loop question
I have a 1992 F150 5.0L E4OD trans. It is running in open loop all the time. I thought that after the engine was warm/hot it should got to closed loop.Am I right or am I wrong? I used a scan tool when it was hot and it said open loop. I am confused the o2 sensor is working as I watched the values on the scanner, engine coolant temp. was 190 degrees, intake air temp was 150 degrees and there is no trouble codes set. Any suggestions? Thanks a million!
Old Nov 19, 2005 | 06:03 PM
Pacerguyel2
please help
Old Nov 19, 2005 | 11:29 PM
mdjohnson's Avatar
mdjohnson
It could be a bad connection to the ECU, but you would probably have a code set. I'll have to ask my teacher on Monday.
