rear end swap
Old Nov 19, 2005 | 09:51 AM
low budget's Avatar
low budget
Question rear end swap
I traded for a mid to late 70s 1/2 ton rear end for my 56 (3/4 to 1/2 ton convrsion)ford but I noticed the yoke is closer to the passenger side a couple of inches and my truck comes straight down the middle , will this cause a vibration ?
I know ill have to move spring perches in.
The overall width I think is close. if i cant use this what years will work better. thanks
Old Nov 19, 2005 | 10:14 AM
LEckart's Avatar
LEckart
The offset side to side shouldn't cause you a problem but make sure you have the pinion angle in phase with the transmission angle or you could have vibration at certain speeds.
