1978 - 1996 Big Bronco
driveline vibration
Old Nov 18, 2005 | 11:56 PM
rharper's Avatar
rharper
driveline vibration
just bought a89 bronco with 176000 has a vibration at highway speed as u coast off of ahill replaced u joints phase marked drive shaft to keep in line also have clunk when kicked down in passing gear problem also present as u roll to a stop .have greased slip joint problem no better could somebody shed some light on this bought this as project and enjoyed it so much have become adaily driver so i really like to fix everthing up
Old Nov 19, 2005 | 01:05 PM
Kemicalburns's Avatar
Kemicalburns
drivelines good be bent and the clunk is probably your rear pinnion nut needs tightened
Old Nov 19, 2005 | 06:47 PM
greystreak92's Avatar
greystreak92
Can we assume that when the U-joints were replaced the centeirng assembly on the double-cardon joint at the front of the rear DS was replaced as well? The syptoms you describe are consistant with a bad centering assembly in the double cardon joint. Thats not to say its the only possibility but both of my Broncos have exhibited the same symptoms when that component began to fail.
Old Nov 19, 2005 | 07:36 PM
rharper's Avatar
rharper
have already checked pinion nut it was not loose as far as replacing centering assembly,bearings fell out and had to put a dab of grease in assembly,then i put bearings back in. drive line had same symptions bofore i replaced u joints could i at this point assume it is probley centering assembly would this possibly also cause the slack i feel thanks id really like to fix this
Old Nov 19, 2005 | 07:42 PM
greystreak92
Yes, it would. The centering assembly keeps your driveline angle correct without the need for a carrier bearing since you in effect have THREE u-joints in a DS that is only supported in TWO places. Something has to be employed to maintain the correct angle or you will get bind because the twi pieces of the DS are not properly aligned. Even though the short piece of the DS is probably less than 4" long, there is still a margin for error. You may not be able feel any slop in the driveline like you do with a bad u-joint. I chased this problem for months the first time it happened to me because I didn't "feel" any play in the driveshaft so I assumed the problem didn't lie there. I was wrong. If you do feel slop the problem is all the worse and repairing it ASAP would be recommended especially if you just replaced the u-joints or the new joints will deteriorate all the faster.
Old Nov 19, 2005 | 09:02 PM
rharper's Avatar
rharper
thanks iwill take care of it tommrow whats a good place to buy center assembly
Old Nov 22, 2005 | 07:16 AM
rharper's Avatar
rharper
well i finally found a center assembly at my local specality store turns out they dont show a center assembly for a 89 bronco thankfullythe guy behind the counter didnt act like the other three places that i went to he actually took intrest in helping (rare) these days after a bit of thumbing thru catalog located part under 3-4 ton pickup have to remeber that may next guy looking for this part.thanks greystreakany how got part installed last night checked rear pinion nut again third time. used cheater bar this time nut actually moved maybe1-8 of aturn got everthing back together and test drove itvibration is gone gone gone!!!!! cant belive it my other problem with kick down clunk not as noticable feels more normal any how this is a greatforum for any one that drives aford truck or bronco!! will tell my friends thanks again
