Exhaust leak
Old Nov 17, 2005 | 11:36 PM
watermanh's Avatar
watermanh
Exhaust leak
Changing oil today and noticed black soot around filter and engine block. Found leak between the block and manifold at cylinder closest to firewall. Not a big leak, but I was wondering if this could cause any other problems? Any advise is greatly appreciated, aloha.
Old Nov 18, 2005 | 07:07 AM
ceopi's Avatar
ceopi
I had the same problem..So I checked all the bolts on both manifolds and the only ones loose was the two that was next to the filter.. I tighten them down and exhaust leak is gone.
Old Nov 18, 2005 | 08:01 AM
1997F-350's Avatar
1997F-350
yes it will really mess up your manifold and its making you lose boost/ performance. our trucks dont come with gaskets originally. most people have to get the manifolds resurfaced when they take them off and then use a gasket. i would try tightening the bolts first.
Old Nov 18, 2005 | 10:19 AM
watermanh's Avatar
watermanh
Thanks for the replies! I tried tightening the bolts but was afraid of snapping them off. I will give it another try after soaking them with some solvent stuff, thanks and aloha.
bkuuz1
Apr 27, 2010 08:27 AM
Bmoney13
Dec 31, 2009 01:27 PM
frenchslandscape
Mar 15, 2009 05:00 PM
FLORESH
Nov 18, 2005 09:55 PM
big block power
Aug 31, 2002 11:18 PM
