9 incher
Old Mar 6, 2002 | 07:26 AM
Southern Fried's Avatar
Southern Fried
9 incher
Hey I got a 79 Bronco with the 9" rear. I had the brake drum off the other day putting a wheel cylinder in and noticed something odd. The flange with the lug studs moves in and out about an 1/8" to a 1/4". What would cause this? How do I fix it? This means the axle shaft isnt held in place right? I need your input! Thanks.
Old Mar 6, 2002 | 08:23 AM
79f3504x4's Avatar
79f3504x4
9 incher
Some end play is normal;check manual for specs.Can be measured with dial indicator.
Old Mar 6, 2002 | 02:06 PM
Southern Fried
9 incher
Oh yea, but this is only on the drivers side the other side isnt that way. It just seems to be a bit much for just play.
Old Mar 6, 2002 | 02:17 PM
79f3504x4's Avatar
79f3504x4
9 incher
If it has a lot of slack it probably needs an axle bearing.4 bolts slide it out press bearing on/off.
Old Mar 6, 2002 | 06:17 PM
Southern Fried
9 incher
That sounds reasonable. Is that something i can do or will I need to take it out and have someone press it off and back on? Requires a press right? Whats involved in taking it out? Once again I thank you for your help, its much appreitiated.
Old Mar 8, 2002 | 07:20 AM
Southern Fried
9 incher
Cool thanks!
Old Mar 8, 2002 | 08:44 AM
Chuck Wade's Avatar
Chuck Wade
Post 9 incher
