400 roller cam thoughts
Old Nov 17, 2005 | 12:43 AM
Wim Crone's Avatar
Wim Crone
Hello All.
I am starting to rebuild the 400 in my 79 bronco. I am thinking that I want as modern an engine as I can to get as much reliability and economy as practical. I thinking of putting a mild roller cam in it. Is there one out there that I can use the 5.0 roller lifters with it? I am using the open chamber 2 barrel heads with a little exhaust work, Edelbrock dual plane intake, badger flattop pistons, headers, and roller rockers. This has a manual trans too.
ALso, any thoughts on the longevity of aluminum roller rockers, or should I just use the Stainless steel ones?
Thanks, Wim
Old Nov 17, 2005 | 09:24 AM
beartracks's Avatar
beartracks
Eric should be along to talk about the ford rollers. I beat the cr** out of a set of Crane basic aluminum rollers for 70,000 miles and they were still usable.
Old Nov 17, 2005 | 03:22 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is some info in some of the posts by TMI on roller lifters. When Tim was here for the National meet we took a look at his engine that he was converting to roller lifters. The reduced base circle cams would not work but a regular base circle cam should work just fine with the stock rollers and spider system. I have a set of stock 5.0L OEM roller lifters to use in my engine but I have not installed them yet.
Old Nov 18, 2005 | 06:50 PM
danlee's Avatar
danlee
I am running a custom Hydraulic Roller in my 400. I used the Comp Cams Retro-fit Kit with the 5.0 spider and dog bones. I am using replacement 5.0 roller lifters. I have Crane Aluminum Roller rockers. I am using guide plates with hardened pushrods. This has been running for over 1 1/2 years now with no problem. (Weekend use).
I believe that this setup is more reliable than the flat lifter setup. Some here might prefer the Scopion Pedastal mount roller rocker to the stud mount for relibility.
