89 F250 XL Ignition Switch Problem
Old Nov 16, 2005 | 08:02 PM
ccached's Avatar
ccached
Question 89 F250 XL Ignition Switch Problem
I have read several folks and the threads for dealing with the problem of an actuator. I have removed my steering wheel and turn signal switch guts and I can see where the ignition key turns clear down and up, but with no resistence. From what I have read that is the actuator rod, and it is broken to allow this? How do I disassemble the rest of the steering column, or do I? How do I remove the ignition switch? Or do I have to - to get to the actuator? Basically, I've never worked on my 89 F-250 because I have never had to! This rig is in super clean condition and all I have done is typical maintenance. Any step by step instructions would help me greatly!!!!
ccached - doug
Old Nov 16, 2005 | 08:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have here. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
