Sponsored by: Real Truck
help with heated mirrors
Old Nov 16, 2005 | 05:23 PM
99f350sd's Avatar
99f350sd
I don't have drawings for 04 heated mirrors. What I need to know is putting the 04 mirrors on a 02 with no heat wires how do I hook it up so it will be like factory...Relays etc..wire color maybe you could email me a print.
Thanks
Dick
Old Nov 16, 2005 | 05:43 PM
FortyFords's Avatar
FortyFords
99 ,I wouldn't hook it up like factory ,Id use an eplorer rear defrost sw for the heat.
That way the heating elements would last longer and less drain on batt/alt.
you have 99 right are you wanting to put them on the 99?
do you have the mirrors yet?
I have the schematics for a 02 we can figure it out.
Rich
Old Nov 16, 2005 | 08:01 PM
99f350sd's Avatar
99f350sd
No its for a friend he has the 02. Don't the def sw's use a timed relay in the circut?
I agree to have it on when you need it.
Dick
Old Nov 16, 2005 | 10:03 PM
jasonlasvegas's Avatar
jasonlasvegas
Has anybody put a switch in the 04's to save on the heater element???
Old Nov 17, 2005 | 08:06 AM
FortyFords's Avatar
FortyFords
Dick
Yes the timed function is done within the gem module.
The switch can still be used,depending on current drawof the heating elements.
Rich
Old Nov 17, 2005 | 09:00 AM
rwilimo's Avatar
rwilimo
Has anyone seen a heater element fail?
