4wd stuck in low
Old Nov 16, 2005 | 04:25 PM
explorerford1999's Avatar
explorerford1999
Question 4wd stuck in low
I have a 99 Explorer 4.0L and when I shift it into 4 low it will not shift back to auto. I know the vehicle must be in neutral to shift and so forth. The only way I can get it to disengage is to place it in auto and disconnect the battery and reconnect it. It's fine until I need 4 low then I have to do the same process over. I see there is a TSB #13745. Anyone else have this problem and how do I fix it?
