1995 5.8 VIN#s
Old Nov 15, 2005 | 05:40 PM
fordxl68's Avatar
fordxl68
1995 5.8 VIN#s
There are two vin. #s for a 1995 5.8 One is H the other is R. What is the H 5.8 and whay is the R 5.8. and can the engines be interchanged with each other. Will the ECM from a 1995 5.0 work with a 5.8?
Old Nov 15, 2005 | 11:41 PM
Blurry94's Avatar
Blurry94
I believe the H is an HO motor and the R is a Lightning motor.
A 5.0 PCM will run both, but aftermarket tuning is recommended, with that PCM, because of the added cubes.
Old Nov 16, 2005 | 04:21 AM
baddad457's Avatar
baddad457
"H" is for the std 5.8 ( not HO) "R" was for the Lightning.
Old Nov 16, 2005 | 05:15 AM
fordxl68's Avatar
fordxl68
what tuning do I have to do ? would it be better to get a PCM for a 5.8 from a junk yard?
Old Nov 16, 2005 | 12:40 PM
Blurry94's Avatar
Blurry94
H is for standard 5.8. I was in the middle of researching HO cam casting #'s when I typed this.
It'll run and drive without a chip and that PCM. Finding a 5.8 PCM of a similar year should not be too terribly hard though and would be a better option.
Old Nov 16, 2005 | 05:16 PM
fordxl68's Avatar
fordxl68
thanks for the help. I'll get a PCM for a 1995 5.8. If you think of anything else that will help me let me know. Thanks, Mike
