'73 and '85
Old Nov 15, 2005 | 02:39 PM
fordflaresides's Avatar
fordflaresides
'73 and '85
I just put a 1985 300 cu in. in my 1973 replacing a '73 240 cu in. I used the manifolds, distributor, carb, and fuel pump from the '73. Was this a mistake, or do they interchange? I am having trouble fine tuning the engine, it runs and drives, doesn't stall, just idles rough in drive.
Old Nov 15, 2005 | 02:40 PM
ford390gashog's Avatar
ford390gashog
well what vacuum is it pulling in drive? that is where i would start.
Old Nov 15, 2005 | 02:44 PM
fordflaresides
I don't have a vacuum gauge handy at the time but if I take a vacuum line off while in drive it has strong suction, I know, I know I need to get a vacuum gauge. Why would you start with vacuum? I am fairly new to auto mechanics.
Old Nov 15, 2005 | 09:32 PM
plowpusher's Avatar
plowpusher
you've done all the basics? all plug wires good, timing in the right range, carb idle mixture right, take a can of WD-40 and spray it it down the carb throat if the engine speeds up you have a vacum leak then spray it on any place vacum is made, intake gaskets, carb base,throttle shaft,vacum lines, ect another thing to look at inside the choke housing is a vacum piston for the choke pull off these make a great hidden vacum leak on 6's usually a ruff drive idle is caused by a miss under load and a vacum leak will give you a lean run condition
Old Nov 16, 2005 | 07:01 AM
Pre'80's Avatar
Pre'80
Timing is off, idle mixture is lean, and vacuum leak are good things to check for.
