1978 - 1996 Big Bronco
Vent window not sealing
Old Nov 15, 2005 | 10:39 AM
Bimmerboy1989's Avatar
Bimmerboy1989
Ok heres my problem, when I close the Tri-Angular vent window it leaks air in the front corner. I looked at the window and it's not sealing at the front corner, it is just off. Do I have to replace the seal? or is there an adjustment procedure?
Old Nov 15, 2005 | 12:03 PM
greystreak92's Avatar
greystreak92
Replace the seal. The only adjustment per-se is the tension on the pivot point. Mine has the same problem but its along the edge nearest the latch. The temporary fix that I current employ is a nickel between the latch and the vertical bar which effectively squeezes the window closed just a bit tighter than normal.
