1964 F-100 Straight Side "Tail Light Panel"
Phil
The only reason possibly is leagal issues with licensure of the product as a replacment .
Just like the 66 to 77 bronco speedometers are a direct replacment for the standard round speedo. But has the added oil pressure and amp guages in stead of the idiot lights. The Dakota Digital set works for this app also but is only advertised for a bronco...when swapping just need to remember to ask for bronco sending units as they will not be listed in a lite duty truck application when using the stock bronco speedo.
The bronco half quarters also work close enough as a repair panel for the wheel opening of the 64 to 66 beds.
Another swap part is to put the narrower bronco 9" rear in a slick. This is a cheap method of getting bigger meats in there with a reasonable offset to the rims.
Garbz
Garbz
