1995 F-150 has brand new 2-week old diehard in it. I do have a somewhat loose neg. cable, but don't believe that should be the prob..
Also, it seems the starter is making it's connection as I can here the armature engage when I turn the key. Haven't pulled pos. cable to see if alt. is bad, but just don't know. It's raining now.
Will jump and run and won't start after ignition is turned off. Will jump in the a.m. and and ck. alt..
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
The negative is just as important as the positive. Electricity needs a return path or it won't flow.
Actually the electrons flow from negative to positive... fwiw.
Tim
